I finally hit bottom
Old 04-25-2012, 03:23 PM
tlinget's Avatar
Default I finally hit bottom
It's low and mean.. but I need some advice.
With Koni adj. struts (yellow -part # 8241-1139SP) and Intrax springs (part # 17001) the rear end bottoms out too easily. The handling is excellent...
What can I do to soften the blow? I'm worried about doing damage when I hit unpredictable road rash, sudden dips, train tracks etc..
I don't mind raising up the back a bit if there's an easy way.
thanks!
Old 04-25-2012, 03:26 PM
Guitar's Avatar
You can adjust them to make them firmer which will help a bit...also do you still have bumpstops?
Old 04-25-2012, 03:33 PM
tlinget's Avatar
Not sure what the bumpstops are/
the Rear is not Koni they are Monroe Sensatracs... is that the issue?
Is there a bump stop I can add to the front/rear?
Old 04-25-2012, 03:50 PM
speed_demon24's Avatar
That would only help if he has double adjustables, adding more rebound won't do a thing.
Old 04-25-2012, 03:54 PM
z28bryan's Avatar
For one thing, if the compression was adjustable it's not really meant to be adjusted firmer to help cause less suspension travel aka help stop prevent you from hitting bumpstops. Compression is set to control unsprung weight. It's just a bandaid. If you want to do it that's fine by me but I'm just tossing this in to prevent any misconception info from spreading around.
Since he's got single adjustables, he can only adjust rebound which won't change anything.
Monroe Sensatracs and Intrax springs huh? Yeah that sounds like a recipe for bottoming out alright!
Old 04-25-2012, 04:01 PM
hodge9386's Avatar
yes that is your problem, monroe sensatracs are crap. i had them on my car foever and my tds would drag the tip everywhere, as soon as i put on my bilstien hd's and strano springs it stopped and was much firmer out back.
Old 04-25-2012, 04:02 PM
VinR1's Avatar
With the intrax springs (which I have btw) you need a quality shock (Bilsteins minimum), isolators, and bumpstops. I drilled holes in my ES bumpstops to ease the shock of hitting them which Ive only done once. The most important thing is knowing the road you're traveling, plan your route, and know what/what not to avoid
Old 04-25-2012, 04:18 PM
Guitar's Avatar
Didn't check his link, didn't know. I just know that when I adjusted mine it seemed to help the rubbing I was getting. I see what you mean by your post though.
Old 04-26-2012, 10:20 AM
ls1jorge's Avatar
Where can I buy a set of intrax springs?? I've no luck in finding them online.
Old 04-26-2012, 11:11 AM
VinR1's Avatar
No longer made/sold from what I have found
PM what you're willing to pay for mine (below and sig pic)
Quick Reply: I finally hit bottom
