Knocking noise
Knocking noise
I have a loud knocking noise coming from the passenger side fender well I think it is the ball joints. Because it makes the knocking or popping noise when I make 90 degree turns, back up and turn, or when I come to a stop. Is it the ball joints, tie rod ends or the strut mounts? Please help I would like to get the parts tomorrow to fix this embarrassing noise.
Check that the adjustment bolt holding the lower control arm to the K member isn't loose. Mine did that and my camber would go WAY off when going in reverse but in drive it straightened back up.
