Cutting stock spring question
Old 05-14-2012, 08:00 PM
VandykeT/A's Avatar
Default Cutting stock spring question
I know cutting them isn't ideal but do I need to cut the tops or the bottoms? I would imagine the tops but just making sure.
Old 05-14-2012, 08:46 PM
VinR1's Avatar
Bottoms of the fronts, tops of the rears
Old 05-14-2012, 09:32 PM
ranman02ta's Avatar
i cut my stock ones. i like the out come. cutting the front is trickery but can be done on car
Attached Thumbnails Cutting stock spring question-c.jpg   Cutting stock spring question-t.jpg
Old 05-14-2012, 10:15 PM
VinR1's Avatar
What did you use to cut them and how much of each spring?
Old 05-14-2012, 10:18 PM
Pontiacerator
RevGTO's Avatar
I did tops on both. Worked out fine but I didn't really like how the rears looked after cutting. Not an issue with the weight of the car compressing them though.
Old 05-14-2012, 10:24 PM
ranman02ta's Avatar
on the front i used a spring compressor from auto zone free barrow. i cut the front with a dremal and a cut off wheel. one full coil
the rear i used a regular grinder and metal blade 1 1/2 coils
i did the cutting of the stockers due to reading posts of some springs sagging.
Old 05-14-2012, 10:51 PM
bones_c's Avatar
how much did that lower the car? mine looks like an off road now... will this mess anything up with drag racing the car?
Old 05-14-2012, 10:52 PM
bones_c's Avatar
oops just seen the pictures but my question still stands on the effectivness of drag racing...
Old 05-17-2012, 07:32 PM
ranman02ta's Avatar
front stock 26 3/4"
rear stock 27 3/4"
after front 25 3/4"
rear 26"
dont know about drag.
Quick Reply: Cutting stock spring question
