Quick Torque arm install question
Old 05-21-2012, 10:51 AM
mjs1012's Avatar
Default Quick Torque arm install question
I recently took my torque arm off when I pulled my motor and was wondering if it has to be torqued back down. If so to how many ft lbs. thanks.
Old 05-21-2012, 05:09 PM
mjs1012's Avatar
anyone?
Old 05-21-2012, 07:19 PM
95LTXZ28's Avatar
I dont know the torque spec and this may not help at all but one thing I would do to make sure everything stays where it should is to put the bolts for the torque arm in from the top of the rear. The reason I say this is because when I swapped to the UMI torque arm I put the bolts in through the bottom and one day I was driving and heard a TING kind of noise under the car. I put it on the lift and one of the bolts fell out of the torque arm. This scared me so I would suggest to put them in from the top so that even if the nuts fall off the bolt will stay in the housing. Maybe it was a freak thing but just a suggestion..
Old 05-21-2012, 08:41 PM
UMI Sales's Avatar
Are you asking about the long bolts through the diff housing?
Ramey
Old 05-23-2012, 03:42 AM
mjs1012's Avatar
^ yea
Old 05-23-2012, 08:10 AM
UMI Sales's Avatar
90 ft-lbs with light lube on the threads is a good starting point. Re-check after a few hundred miles or an evening or two of drag racing.
ramey
Old 05-23-2012, 08:39 AM
mjs1012's Avatar
Thanks a lot Ramey. Would you be able to pm me a price on a tubular torque arm? Not sure if I need an adj or non adj.
Quick Reply: Quick Torque arm install question
