Tunnel mounted TA?
Tunnel mounted TA?
Ive been searching for a while and looking at the tunnel mounted torque arms. Does the cross brace that the arm bolts to require welding or drilling on the body to install or does it use exisiting bolt holes?
I don't know about other brands, but UMI's tunnel mounted TA requires no cutting, welding, or drilling. They advertise it as a 100% bolt on part.
From UMI's website :
This set-up requires no welding or drilling and can be installed with basic hand tools; this is a complete bolt-in design.
Just got off the phone with UMI and a tunnel mounted torque arm wouldn't work with my true duals so looks like its full length with a relocation bracket. Thanks everyone and UMI has excellent customer service will definitely be ordering soon.
Yep, costumer service is top knotch! Didn't know you had the true duals. I will be getting the full length with relo anyways\
P.S. - Where in Ill are you from? Cedar Lake, Indiana myself
LS1Tech Premium Sponsor
Our torque arms that are considered tunnel mounted are all weld in. We've found that the thinner gauges metal where some tunnel mounted arms bolt to were never meant to see those kinds of forces, especially in higher torque cars. This is why ours weld-in to the subframes and displace the force through the chassis.
2002 Camaro SS with duals, UMI torque arm and relocation kit
