Koni shocks and dana 60
I have Strano springs and Koni SA for the front. Last year i added a Dana 60. I have heard a bunch of differnet things about shocks for the rear, I have Bilstiens on the rear now. I have heard to run 4/3 over the 4/4 for the heavier rear. I daily drive this car more than anything but do frequent the dragstrip. Do i get 4/4 for the on car adjustability and double valves or the 4/3 for the bigger single valve and lose the on car adjustability? Looking for better 60 ft times.
Ive been reading all day and just want some advice!! Thanks
Jason
Jason
The 4x4's are still only SA for rebound, and while the rears are adjustable on-car, you still won't be able to change the compression settings to counterract the increased weight of the S60. Ideally, you'd want DA's on the rear to tune both rebound and compression. Whether the additional cost of the DA's is worth it is up to you.
