subframe connector question
Old 05-30-2012, 04:26 PM
lsmaxxed's Avatar
Default subframe connector question
I have had umi 3 point bolt ins on my car for a fee months and want to no of it matters if the car is with the wheels on the ground or in the air does it mater? I am noticing some small ripples in the quarters
Old 05-30-2012, 06:22 PM
kylemm1002's Avatar
All subframe connectors are supposed to be installed with the suspension loaded, so wheels on ground or jacked up by suspension points.
Old 05-30-2012, 07:01 PM
ShifterLou's Avatar
^^^ this.
Old 05-30-2012, 08:05 PM
UMI Sales's Avatar
We recommend final welding or bolt tightening be done with the car as its going to be driven.
Old 05-30-2012, 08:12 PM
autogeek23's Avatar
I'm glad this was posted. Now I know
Old 06-04-2012, 08:41 PM
lsmaxxed's Avatar
Default s
so can i just loosen the bolts that attach to the front subframe and just re-tighten them while im under the car? would this be good?
Old 06-04-2012, 09:37 PM
UMI Sales's Avatar
Yup. As long as the car is on its tires or is jacked up under the suspension (so the suspension is loaded). Just loosen the paddles and the tunnel brace points, rock the car a bit, then retighten.
Ramey
Old 06-04-2012, 09:42 PM
JUSTINSWS6's Avatar
I did mine on a trailer since my lift has 4 arms and took out the inner boards so the wheels where on 2 boards each and had more room.thats a thought if you have one.
Quick Reply: subframe connector question
