ABS Delete...now no lights!
Ok guys, I installed the SJM abs delete on my 94 camaro. I also removed the wiring running back into the cabin from the abs module. Now it seems that I dont have radio power, interior lights, brake lights or parking lights. Headlights still work. Has anyone else experienced this issue? Im wondering if this is related.
Any help is appreciated.
Check your fuses. Check the firewall connector. None is related to the ABS controller or ABS computer or wires leading from each component. You may have clipped or pulled the main buss which connects through the firewall.
Good luck!
Good luck!
the brake lamp uses a ground through one of the wires, but that would only create the lamp to illuminate under certain circumstances. That is also easily remedied.
Shouldn't have had to install another switch tt383.
