Help...pop/clicking noise at rr wheel
Old 06-10-2012, 04:54 PM
rokinv8's Avatar
Default Help...pop/clicking noise at rr wheel
Got a question. A few months ago I installed BrakeMotive rotors and brakes all the way around. All was good until yesterday. I am now getting a pop or click noise about every rotation of the RR wheel. I jacked the car up and if I turn the wheel by hand it gets a little tighter at about 1 revoultion, then clicks, then continues to spin a little easier. It does this every revolution of the wheel. Any ideas? I have looked over everything and it all looks good.
Old 06-10-2012, 05:05 PM
my_99Z's Avatar
Sounds like your caliper is tapping the rotor at a certain spot look on the rotor where the wheel bolts up to it and where the bottom or top part of the caliper goes around it. Installed aftermarket rotors and calipers on my Nova and it was doing that, could be the caliper got a little loose or it's just rubbing. All I did was grind it down a bit with a file and it never made that noise again
Old 06-10-2012, 05:06 PM
my_99Z's Avatar
You might see some wear on the rotor where it's doing it too
Quick Reply: Help...pop/clicking noise at rr wheel
