ABS kicks in at low speeds
For a couple days now, my ABS INOP and ASR OFF lights have been coming on. Today, my ABS decided to come on when I was just creeping forward in traffic. I felt the felt pulsate when I stopped on dry pavement from not even 5 mph. Could be a sensor not plugged in all the way? Bad ground?
I had headers put on the car a couple months ago. About a month ago I slid off the road from snow and bent both axles. The dealer replaced the axles and the right rear rotor.
If you can find a way to pull the code it will direct you to the offensive wheel sensor or other problem. Until then all you can do is check connections and visible wiring. You could also ohm check all wheel sensors to see if one is differant then the others
I've had the exact same problem since having my headers installed about a week ago. Got the car back and the lights were on. I had it scanned and it showed one of the rear speed sensors was bad. I pulled it out and cleaned it up but no difference. Looks like im gonna have to fork over the $100 for the part. Anyone know of a better price on them?
I checked for codes and nothing's shown up yet. I cleaned the rear sensors and connectors and that didn't make a difference. I might try and clean the front sensors tonight. It's very intermittent but seems to be happening more often now (lights coming on, not ABS stepping in).
The front sensors don't appear to come off like the rear ones do. Nothing was wrong with the connectors on the front though. I tried resetting the PCM and that doesn't do any good. Double checked the fuses and they're all fine. I have noticed that if the lights come on at startup, they go out when I pull out of my parking space (moving forward and turning right away).
Copy & Paste Moderator
What about the surface that the sensor reads. I don know if f-body brakes are like this, but on some ABS systems, the sensor reads a slotted wheel or tothed wheel (possibly on the back of the rotor). Check that out, maybe its damaged/gummed-up/blocked.
I saw that wheel on the inside of the rear rotors but not on the front. Must be behind a cover. Resetting the PCM *may* have fixed the problem. I haven't had any problems yet today. The car saw a lot of dyno time a couple weeks ago so that may have caused it.
--VIP1
