New Suspension and still getting wheel hop!!
I just put on my new torque arm, panhard bar, LCAs & brackets, and sub frames from BMR and I am still getting wheel hop! We installed the suspension on a frame lift, and then move it over to a drive on lift and tightened everything up. My pinion angle is sitting right now at -4, and my LCA's are on the bottom hole of the brakets. I have ordered a moser 12 bolt and will install it next weekend, but I am wondering if I will still have the same problem. Also I am getting more rattle noise from the rear end, but I am pretty sure thats from the stiffer suspension. Anybody know why Im still getting wheel hop?
Thanx
Nakoz
Thanx
Nakoz
ever look into HOLE SHOT BAGS?????? take a look i installed a couple in high power cars and the make alot of difference. also with wheel hop shocks and torque arms are a big player, check and replace as needed. the shock should feel warm after driving for about 10-15 min.
Mike
Mike
that weird after i put in a torque arm my problems are gone, also u set the pinion angle a -4 ,i had eastside install mine and they set it at -1,my car is lowered not sure bout yours
Ok cool, ill reset my pinion angle to a -1 and then see what difference it makes, I think also I am going to wait and see what the 12 bolt does. Thanks for all the posts guys.
Nakoz
Nakoz
