rhino ramps
Old 07-18-2012, 06:33 PM
astro11271984's Avatar
Default rhino ramps
Not sure if this is in the right section but how do you all go about getting your lowered cars on rhino ramps
Old 07-18-2012, 07:45 PM
2win_SS's Avatar
Jack the car up then set the car on the rhino ramps... Done
Old 07-18-2012, 07:47 PM
trans_am7935's Avatar
check out the second picture down, he did them right. he is on Strano springs:
https://ls1tech.com/forums/suspensio...alignment.html
Old 07-18-2012, 07:50 PM
2win_SS's Avatar
^^^ nice find
ChrisRZ28's Avatar
I used to use steel ramps and got tired of fighting to drive up on them, so I made these out of 2x8s.
Old 07-18-2012, 08:04 PM
Thats how i do it but gets old quick doing each side little by little trying to keep the car even looks like ill be making my own ramps and selling mine to offset the cost of lumber
Old 07-18-2012, 08:19 PM
SparkyJJO's Avatar
I hate ramps. I'm just going to dig a pit when I have my own place
Old 07-18-2012, 08:21 PM
Wish i had a garage then i could get a lift my neighbors are worried because im under my car so much lol
Old 07-18-2012, 08:22 PM
ranman02ta's Avatar
been there tried that,,,, I got 2, 2 ton jacks and do one side at a time and put on stands.
works for me
z28bryan's Avatar
Now that I have a garage, all my rhino ramps do is slide across the floor when I try driving on top of them. When they did hold, I'd just drag my OEM ground effects pieces on them. I don't really take the best care of my car appearance though, lol
Another cool trick I do once in a while is when I'm driving off of them if they are on the rear of the car is give it a little gas and fire them backward and slamming the back tires on the ground
Old 07-18-2012, 09:22 PM
lol....dont do this
Old 07-18-2012, 09:54 PM
99Bluz28's Avatar
If you have a problem with them slipping get a set of rubber floor mats and put them half way under the front of the ramps and drive right up on them.
Old 07-18-2012, 11:20 PM
zaaronz's Avatar
Now i have a new project lol I gotta have a set of those!
Old 07-18-2012, 11:36 PM
bill12690's Avatar
Don't know exactly what brand they are (I can check) but I have some plastic ramps and my car clears them fine, also on stranos. Also cleared them on the pro kit..
My only problem is I wish they were wider, they're barely wide enough for 275s
http://youtu.be/rnmqX02v_mU
Old 07-19-2012, 01:24 AM
TruBloodTransAm's Avatar
I have Rhino Ramps and I can roll on just fine. I'm on Koni's/Strano's.
Old 07-19-2012, 01:30 AM
speed_demon24's Avatar
Same here
Old 07-19-2012, 06:20 AM
2win_SS's Avatar
^^^ why would you do this?
Old 07-19-2012, 08:49 AM
z28bryan's Avatar
Lol, I don't mean to. I should have said, it's not really cool to do this.
Ladies and gentleman, don't try this at home.
I need to try that thing with the rubber floor mats. Hope that works!
I'd imagine anyone who has around a 1.2 foot drop should be ok as long as they have no ground effect kit on theirs. I kick/jam my ramps underneath the factory ground effects and then drive up from there. If they weren't there, it would probably perfectly clear
Old 07-19-2012, 09:14 AM
yah im a little lower than that
Old 07-19-2012, 09:49 AM
99zee's Avatar
Originally Posted by speed_demon24
same here
x3 ...
Quick Reply: rhino ramps
