Ready for alignment?
I just bought a used Koni with ground control front setup. I've been screwing around with the ride height for a couple of days and I think I'm done.
The thing is... the right side is about 1/8 of an inch(used a tape measure) higher than the left side.
Can I get an alignment today? Or do both sides need to be dead nuts accurate? Thanks
Set your ride height first and then match the alignment with it. Reason being is that your negative camber angle of wheel increases as your suspension compresses. For the front only.. not the back obviously.
