My setup
My setup
I just go my UMI torque arm and spohn driveshaft safety loop installed on the car. While I was in a rush to install the torque arm I didn’t check the pion angle and there was a vibration from 2500rpm+, took about 15 minutes to adjust the arm and the vibration is gone. UMI makes great parts and I would recommend them to anyone looking for a suspension parts.
UMI adjustable torque arm
UMI torque arm relocation Kit
UMI 3-point sub frame connectors
UMI nonadjustable lower control arms
UMI nonadjustable panhard bar
UMI front and rear sway bars
Hotchkis Strut Tower Brace
Spohn Driveshaft safety loop
Uploaded with ImageShack.us
It does hit the two bolts that the Drive shaft safety loop bolts to the car but I flattened the pipe a little and it clears no problem as for the TA, the arm is offset to the left just a little bit and the rear lower bolt on the TA will barely hit the turn out under full droop, I just have to bend the pipe over a little.
