Looking for LT1 to LS1 brake conversion info.
Old 08-09-2012, 08:24 PM
1SWT95Z's Avatar
Default Looking for LT1 to LS1 brake conversion info.
Just wondering how involved swapping the LT brakes to LS brakes is and is it worth it? Does anyone have a write up on this or have some good expierence and a list of what is needed? Thanks for any info guys.
Old 08-09-2012, 08:50 PM
trans_am7935's Avatar
LS1 spindle
LS1 brake calipers
LS1 brake caliper mounts
New balljoints (recommended, LS1 style)
LS1 rotors
HPS front brake pads
idk if you need the brake lines to do this, but it wouldnt hurt.
Old 08-09-2012, 09:27 PM
1SWT95Z's Avatar
Alright, thanks for the info.
Old 08-11-2012, 04:43 AM
nascarnate326's Avatar
I have my fronts swaped to LS1 brakes, they are vastly superior. The banjo Bolt is the same as a 2005 Tahoe 2WD FYI.
Old 08-11-2012, 11:05 AM
buellxb12s's Avatar
I have the calipers and mounting brackets for cheap if you want pm me
Old 08-17-2012, 02:47 AM
strokeme's Avatar
So i take it that the wheel bearings are the same? And do any of you know what is different about the balljoints? Reason i ask about the balljoints.. is i just got my car put together last fall and it's got all brand new parts up front. Id hate to change them if i don't have to.
Old 08-17-2012, 05:44 AM
I believe I kept ball joints and hubs from my LT1 parts. I swapped just spindles, calipers, and pads.
Old 08-17-2012, 08:27 AM
new balljoints are not necessary, just recommended, especially if you have over 150k miles. but if they are in good shape, good for you. it is not the end of the world if you dont change them
Old 08-17-2012, 09:40 PM
Badazz 97 TA's Avatar
The spindles are the mounts for the calipers. Don't know why they said you need mounts?? Everything is a direct swap. Any 98-02 fbody will work. V6 or v8. Bearings, abs and joints are the same as lt1 stuff
Old 08-17-2012, 11:23 PM
buellxb12s's Avatar
You have the bracket that bolts to the spindle and the caliper bolts to it ...its not a adapter bracket our anything just the stock Ls1 bracket that holds the clips that the pads slide into
Old 08-20-2012, 04:13 AM
strokeme's Avatar
Awesome, thats what i was hoping! Thanks!
Old 08-20-2012, 05:40 AM
transamtom's Avatar
You can use the LT1 spindles you just need to break out the sawzall to cut off the bracket ears.
Old 08-20-2012, 07:46 PM
Spartan7's Avatar
Ball joints and wheel bearings are the same. You have to bend the brake line bracket slightly to reduce tension on the brake line when turning lock to lock. Use the LT1 brake line, it's longer. Banjo bolts are also the same.
Old 11-04-2012, 03:06 PM
Kubs's Avatar
What do you do about the holes for the newer style caliper brackets?
Old 12-26-2012, 06:42 PM
waxenate's Avatar
Anyone know the length of the lines needed for this swap? Thinking about having some stainless lines made up. I assume they are longer than the LT1 but how much longer? Dont want a bunch of slack out there.
Quick Reply: Looking for LT1 to LS1 brake conversion info.
