Getting the 60fts down.
Old 08-13-2012, 03:45 PM
Troy5061's Avatar
Default Getting the 60fts down.
My car is doing some bouncing up and down when leaving the line hard and I think its hurting my 60fts. Will an aftermarket torque arm help this? I have tubular lwr control arms, panhard rod, new bilsteins, BMR TQ arm relocation brkt with the stock torque arm. The converter is a yank ss3600 and the tires are MT ET street radials 295/50R16.
Best 60ft time is in this video, 1.65 and you can see it doing the bouncing, didnt really feel like wheel hop when it launches.
Old 08-13-2012, 03:51 PM
NC98Z's Avatar
Are you still running a front sway bar? Running 18#s in the back?
Old 08-13-2012, 04:21 PM
djfury05's Avatar
Need better shocks, more weight transfer to the back.
Old 08-13-2012, 05:01 PM
bwkmaro's Avatar
what kind of shocks you got?
Old 08-13-2012, 05:07 PM
02sleeperz28's Avatar
This.
Old 08-13-2012, 05:22 PM
Troy5061's Avatar
Stock front sway bar, bilstein shocks all around, 17 psi in the rear tires.
Old 08-13-2012, 05:30 PM
Troy5061's Avatar
Stock coil springs.
Old 08-13-2012, 07:06 PM
djfury05's Avatar
Next time at the track until you can afford new shocks try removing the sway bar up front. It helps transfer weight better.
Old 08-13-2012, 08:15 PM
garygnu's Avatar
with that much power I think a adjustable torque arm would help.I think you need better springs and adjustable shocks .remove the front sway bar and get a bigger rear sway bar.
