rear height adjustment?
Old 04-06-2004, 11:00 AM
98TA86's Avatar
Default rear height adjustment?
Does anyone make anything out there to adjust the rear spring height?
Thanks
Old 04-06-2004, 01:58 PM
Moderator
jimmyblue's Avatar
Air shocks work, as long as you want more height.
If you took out the spacers & sleeved w/ heater
hose you'd drop about 3/4" and could raise it from
there to your liking.
Old 04-06-2004, 05:12 PM
OC BLACKZ28's Avatar
Thanks
Check out Ground Contol kits, they work well. They sit between the spring and differential and thread up and down.
http://www.ground-control.com/?D=72f...7607aca9045a31
