Removing Control Arm Bushings
Well guys my car is up and over 100k so I figure its time to go with some new bushings underneath to hopefully improve the ride quality. I dont want any squeaks or harsh ride so I'm looking at doing all moog replacement stuff up front ads well as in the rear lca's. My dilema is that they look to be sort of a pain in the *** to do.
All of the installs on here I find are about poly bushings, what is the best way to remove the rubber and sleeve from the arm? I was thinking about burning the rubber out then using a chisel to collapse the sleeve and hammer it out or using a ball joint press. I also have access to a 2 ton press but I think it would be hard to get the arm securley locked into it. any help is appreciated.
I just did this to my car plus 4 new ball joints and outer tie rods, but I had a machine shop take care of the press work as ripping the suspension apart and putting it all back together for work on Monday was enough work for me, especially installing new springs, shocks, and antiroll bars. They charged about $10 per bushing/ball joint they pressed out-then-in. Just an option if you choose to let someone with better tools handle it.
