getting there with the suspension
Old 09-08-2012, 08:45 AM
unioncarpenter84's Avatar
Default getting there with the suspension
just installed umi panhard bar and lower control arms...
i have those kyb 8 way adjustable shocks good or no??
whats other things needed to get better et besides a torque arm thts the nxt purchase
Attached Thumbnails getting there with the suspension-561058_463386923684691_1510858565_n.jpg
Old 09-08-2012, 09:14 AM
therealcreeper's Avatar
what do you do with the car? drag/street/autox/road race?
Old 09-08-2012, 09:15 AM
street and drag occasionally
Old 09-08-2012, 08:20 PM
UMI Sales's Avatar
Nice! Thanks for installing UMI.
KYB's on 1 is your best bet for drag. 3 is a good baseline for street.
Old 09-09-2012, 08:30 AM
why is one the best??
the problem im having is tht the car is squatting to the passengers side way to much is one the firmest??
so the question is whats one mean?
and whats eight mean?
thanks
Old 09-09-2012, 08:40 AM
garygnu's Avatar
consider a 25mm rear sway bar to help when drag racing.
Old 09-10-2012, 08:23 AM
UMI Sales's Avatar
We use 1 for drag racing since 1 is 5% softer than stock. A bit looser on extension helps the weight transfer to the rear and the softness out back allows the tires to hook. Keep in mind these aren't drag shocks but we make due with what is on the car in each case.
And yes, increasing rear sway size will help. We also have a drag bar available which really flattens the car out on launch. Street manners are jeopardized a bit as it makes the back end loose from a handling standpoint but the reward is helping the car leave flat as a pancake...
ramey
thanks
Old 09-10-2012, 05:59 PM
ramey
ya i understand there not drag shocks but if i put them on one will the car squat real bad??
whats the best number for the car not to squat
Quick Reply: getting there with the suspension
