Difference between stock 32mm and aftermarket 32mm front sway bar?
I have a 2000 ss camaro and looking at a craigslist solid spohn 32mm front sway bar. Did a little search on here, looks like i have a 32mm stock sway bar so my question is should i buy the spohn? Why go aftermarket if its the same size?
Did some more research when i got home and I agree probably an upgrade from 30 to 32. Thanks ls1tech fo not letting me buy the same dia bar I already had. Looks like I need to look for a 35mm bar.
The Difference is stiffness in the bar itself here are some numbers on bars
Bar OD in ID in Arm in OD mm ID mm Arm mm Relative Stiffness
Hellwig 1" solid 1 0 6 25.4 0.0 152.4 17.921
hypothetical Hellwig 1" hollow 1 0.688 6 25.4 17.5 152.4 13.906
Hellwig 1" solid 1 0 7 25.4 0.0 177.8 13.167
Hellwig 7/8" solid 0.875 0 6 22.2 0.0 152.4 10.505
hypothetical Hellwig 1" hollow 1 0.688 7 25.4 17.5 177.8 10.217
Hellwig 1" solid 1 0 8 25.4 0.0 203.2 10.081
hypothetical 25 solid short arm 1 0 8.25 25.4 0.0 209.6 9.479
hypothetical 25 solid long arm 1 0 8.5 25.4 0.0 215.9 8.930
Hellwig 7/8" hollow 0.875 0.563 6 22.2 14.3 152.4 8.705
hypothetical Hellwig 1" hollow 1 0.688 8 25.4 17.5 203.2 7.822
Hellwig 7/8" solid 0.875 0 7 22.2 0.0 177.8 7.718
Hotchkiss (25 hollow short arm) 1 0.688 8.25 25.4 17.5 209.6 7.355
hypothetical 24 solid x x 8.5 24.0 0.0 215.9 7.118
hypothetical 25 hollow long arm 1 0.688 8.5 25.4 17.5 215.9 6.929
Strano with MarkA's adj conversion 0.875 0.5 7 22.2 12.7 177.8 6.895
Hellwig 7/8" hollow 0.875 0.563 7 22.2 14.3 177.8 6.395
hypothetical 23 solid x x 8.5 23.0 0.0 215.9 6.004
Hellwig 7/8" solid 0.875 0 8 22.2 0.0 203.2 5.909
Strano with MarkA's adj conversion 0.875 0.5 7.75 22.2 12.7 196.9 5.625
hypothetical 22 solid x x 8.5 22.0 0.0 215.9 5.026
Hellwig 7/8" hollow 0.875 0.563 8 22.2 14.3 203.2 4.896
Strano with MarkA's adj conversion 0.875 0.5 8.5 22.2 12.7 215.9 4.676
Hellwig with MarkA's 1" extension 0.875 0 9 22.2 0.0 228.6 4.669
Strano x x 8.5 22.0 14.0 215.9 4.201
1LE x x 8.5 21.0 0.0 215.9 4.172
Strano with MarkA's adj conversion 0.875 0.5 9.25 22.2 12.7 235.0 3.949
Strano with MarkA's adj conversion 0.875 0.5 10 22.2 12.7 254.0 3.379
Stock V8 x x 8.5 19.0 0.0 215.9 2.796
Stock V6 x x 8.5 17.0 0.0 215.9 1.792
Actually you are right. I take that back. Arm length, aka where the endlinks are mounted can have an effect on bar stiffness. But if both bars are around the same length and are both hollow or both stiff, they are pretty darn close.
LS1TECH Sponsor
The difference between a hollow and a solid bar isn't as much as you'd think. It also matters what kind of wall thickness the hollow bar has.
I think you are wasting your money to move from a GM 32 to a solid 32, personally. Which is why I developed a hollow 35. There are solid ones too, I used to make them until I went hollow because the weight is significantly less (about 13-15 pounds less) than a solid bar.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
I don't have any unboxed at the moment, and the rear bar comes with extra mounting hardware.
Boxed up (big boxes, 56x21x3" and with all the hardware needed, links, bushings, mounts, nuts and bolts, washers) the front bar is 23 and the rear is 20. Remember that's with everything including the boxes... The bars alone are much less. Front is about 17, rear is about 5 (there is more hardware with the rear to mount is and make it adjustable).
__________________
