anyone running lakewood shocks and struts
thinking bout getting new shocks and struts for my trans am. flipping through ws6store i came across lakewood struts and shocks thinking about 50/50 rears 70/30 fronts. si anyone running them one the street.
you're not gonna get a lot(if any) of replies.
Back in the 60s/70s(yea,I'm old),Lakewood was a very popular/used product line. 'Scattershield' bellhousings,shocks,control arms for the GM musclecars of the era. Since then,other manufacturers have surpassed them and thier product line. Not saying thier shocks are bad,but nobody uses them, They have 'traction bars' for f-bods,which if you do a search for that product in this forum,a high percentage of failures. Thier traction bar has been replaced in usage by the common 'LCA relocation bracket' available from many manufacturers/vendors.
I've used thier shocks back in the 60s/70s,nothing special.
And there are plenty of companies that are in business that only churn out crap. Not saying Lakewood is, but just stating the obvious
Maybe you should buy them and test them out? Take them to an autox course and a drag strip, and see how they perform in both of those.
LS1TECH Sponsor
Wow, how is $379.99 "top dollar". And I guess the inverse is true, why are people so hell bent on saving a few bucks and running a POS shock?
Here's the deal.... Drag shocks which those are, aren't about control, they are about weight transfer. Fine for drag racing if you can hang onto the car at speed (notice how much drag cars tend to move around at the big end?????). But not so good for the street.
Lots of crappy stuff exists and gets sold. If it didn't cheap Chinese crap wouldn't be all over, Harbor Freight would never sell another tool.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I run these on my street / drag car running the lsx series in rumble great shocks for drag racing I do not drive aggressive on the street like i would with a set of stranos.
But they ride great and definitely transfer the weight and then hold it.
can't tell much difference then the stock until you punch it in a straight line.
I would buy them again.
LS1TECH Sponsor
The difference you feel in a straight line when you punch it is a lack of rebound... that's what causes the car to "weight transfer". It's also what causes the car to feel a little floaty, and generate a lot of body roll quickly.
__________________
LS1TECH Sponsor
Sam i was more curious on how the performed they caught my eye will flipping through ws6store.com the other day. im probably going to with your bilstein/strano spring package. i also seen the tokico package you had on your website. my uncle brian burdette told me to go with koni's. since thats what he ran on his scca camaro. but my car does get driven that much and doesnt run the autocross course but does see the track 5 or 6 times a year. i was looking for a good upgrade to the warn out factory stuff. in your opinion what would be better the tokico's or bilsteins along with your lowering springs
Bilstein's are much, MUCH better shocks. The HP2 kit is a set of those and my springs at a bit of a discount. And I can ship them in one box too, saving some shipping cost (cannot ship Tokico's that way).
__________________
would the bilsteins transfer weight better than stock shocks while still bieng ok on the street?..my car is not a corner carver and does occasionally see the track and a few street races/weekend toy
LS1TECH Sponsor
What you have to understand is "weight transfer" is the car flopping around, basically. There is a reason you see bagged out Nova's with original shocks "weight transferring" really well, the shocks suck. Great for the nose shooting up, not so much for a car you want to drive and be stable and predictable and planted.
You can actually over-transfer and bog the car. I know more than one guy that 60'ed better on Koni's than on drag shocks. Presumably that's because the weight transfer was more controlled. And make no mistake, big time drag cars like Pro Stock do use adjustable dampers to tune this stuff. In fact Koni makes DRAG SHOCKS... which they tell you are NOT to be used on a highway as personal injury can result... because they are about drag racing, not stability.
That said, Bilstein's don't lock the thing completely down anyway and with good bite you will still feel the nose come up pretty quickly... this goes hand in hand with them not having as much rebound as things like Koni Sports (which can be turned down to help with leaving, and up on the street). As a driver shock the Bilstein's are WAY better than Lakewood or even KYB AGX. But if you want something that can be better at each, then I'd recommend AGX's over Lakewood because as much as I prefer the way the Bilstein's drive, the KYB's will drive better than Lakewoods.
__________________
