1le springs
Old 04-15-2004, 09:56 PM
ZDOG's Avatar
Default 1le springs
do you know if they are the same ride height as stock? also how much stiffer are they than stock z28 springs? or the front 2 sufficient or should they be at all 4 corners? thanks!
ps. any part #'s
Old 04-16-2004, 06:59 AM
ross's Avatar
Here is the data streight off of GM's Chassis Tunning Chart for the 1998 models (Don't ask how I got it)
FE2 Solid Roof and T-Top (Z28):
Ft: 51 N/mm (291 lbf/in) Streight Rate
RR: 19.9 N/mm (113 lbf/in) Streight Rate
FE2 Conv (Z28 Vert), FE4 Conv (SS Vert), B4C Police Package, FE4 Coup, (SS), FE7 Showroom Stock Pkg (1 LE)
Ft: 63 N/mm (342 lbf/in) Streight Rate
RR: 20-30 N/mm (114-171 lbf/in) progressive rate
The ride height is the same for all cars.
Eibach Springs, Pro Kit:
FT: 377-600 lbf/in progressive rate
RR: 94-160 lbf/in progressive rate
The Pro kit will lower the car about 1.5 inches
Old 04-16-2004, 09:30 AM
ZDOG's Avatar
thanks, anyone got part numbers?
Old 04-16-2004, 10:18 AM
ross's Avatar
Check out this link:
http://www.1le.net/docs/1le_specific_parts.html
(2) Front springs (LS1, 360 lbs/in): 22132887
(2) Rear springs (LS1, 130-170 lbs/in): 22132889
He has different spring rates, but I got my a very reliable source inside of GM who lets just say, had very close ties to the F-Bodies.
Old 04-16-2004, 11:43 AM
ZDOG's Avatar
thanks, only problem im having is if those are gm part numbers they yeild no results on any gm parts catalog's? ill call my local dealer and find out what the the numbers are for 98 ss with suspension package. thanks for the info.
Old 04-16-2004, 11:47 AM
Kenafin_02TA's Avatar
If you're referring to the 1le suspension components that SLP put on some Firehawks and SS's...they will drop the height about 3/4". I don't know how they compare to a Z28 stock setup...but they are much stiffer than a stock WS6 setup.
You wouldn't think 3/4" would make much of a difference...but it does...more speed bumps get scraped...opening the car door when it's on a trailor isn't always possible.
Old 04-18-2004, 07:49 AM
ross's Avatar
I am glad I could help, let me know how it turns out.
Old 04-22-2004, 09:17 AM
ZigZagZ's Avatar
Would the installation of 1LE springs, on a stock Z28, require 1LE upper and lower control arms? Is the geometry of the 1LE control arms different than the Z28 control arms, or is it simply a matter of different bushings?
Any input would be greatly appreciated.
Old 04-22-2004, 09:35 AM
ross's Avatar
The difference is just a matter of bushings. The geometry is idential.
Old 04-22-2004, 09:37 AM
ZigZagZ's Avatar
Originally Posted by ross
The difference is just a matter of bushings. The geometry is identical.
Thanks Ross
Old 04-22-2004, 09:47 AM
ross's Avatar
No Problem
Old 04-22-2004, 10:03 PM
98_1LE's Avatar
GM no longer stocks 1LE springs. SLP may still have them. I have been told that if you order the 1LE part number, they send a "replacement" part which is the base Z28 spring.
Old 04-23-2004, 08:52 AM
ZigZagZ's Avatar
That sucks.
Quick Reply: 1le springs
