what dictates rear end location?
Old 04-18-2004, 07:06 PM
Beast96Z's Avatar
Default what dictates rear end location?
Front to back? When I put in my Moser 12-bolt, the rear moved further back in the wheel well. My springs are now at a bad angle and the passenger side spring actally hits the panhard bolt. I;m guessing adjustable lower control arms will pull it back into place?
Old 04-18-2004, 08:46 PM
cm02WS6's Avatar
Adjustable control arms will bring it back in. However, what torque arm are you running? I imagine that the pinion angle would change when you move the rear end, so you might need to re-adjust it once the rear is centered.
Old 04-18-2004, 09:00 PM
Beast96Z's Avatar
I'm still using the stock TA. I believe the way it is now is off. I have alot of wheel hop now, and the rear looks like it is pointing more upward instead of straight on like it should be. I will be buying an adjustable TA anyway, so I'll get it one way or another. I just wanted to make sure the adj. CA's could bring the rear foward some.
