Rear Lower control arm play
So wondering if my rear LCA bushings are bad. I have play if I grab the LCA and push and pull it (As in from passenger side to drivers side) I would say its probably about 1/4" total play. Thanks
LS1Tech Premium Sponsor
What kind of LCA is it, factory or aftermarket?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
It sounds like the factory rubber bushings are just allowing more movement than they should. More than like it is probably just wear and tear from age. If you are looking for something to minimze the movement I would just go with a good quality set of aftermarket non-adjustable tubular lower control arms like our BMR TCA001, they are very affordable and perform amazingly well.
BMR non-adjustable LCA (TCA001)
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
