Need help with front end noise
Ok I bought a set of eibach pro lowering springs and just got a around to installing them I didnt have a problem with the rear at all and figured id tackle the front. Once i read a few things off here I took the hole front end apart and noticed that the lower ball joints where shot and the tie rods end where shot so i replaced them both , Heres the problem my strut hardware was very hard to get off and i had to cut the nut off on one side and had to cut the shock on the other which i then had to buy new shocks but didnt have much money so i bought these cheap ones for $60.00 each at auto zone for now which was im sure a bad idea but i wanted it back together now that its back together it makes a nosie when pushing the car up and down and worse when driven it , I took a video for you to hear it sounds like the upper ball joints are shot and need replacing now or the shock is hitting the top of the car ? ? ? .... let me know what you think
Did you tighten up the upper shock bolt inside the mount all the way, when I lowered my car I didn't, and had a similar noise, had to take everything back apart and tighten it up!
yea tighten everything up good , im not sure if its the shitty shocks bottoming out from being lowered or the upper bail joint i didnt replaced but im scared to drive it
I didnt replace the strut mount because they looked good and i didnt have the $160 to replace them either , I wasnt planing on spending all this money on installing the lower kit everything i took off i put right back on except that little piece of rubber that sits in the strut mount i forgot them but those were only small pieces of rubber and wouldnt stop this noise once i take it apart again ill put them in
that black plastic piece didnt go back on because it was cut in half but the rubber piece that slides on the shaft is on there , It could be a bad ball joint on the upper arm the lowers are all new , shock could be blown but i doudt it
