New wheel bearings=abs inob
I have never had a problem with the abs until now. I just installed new Timken wheel bearings and instant light. And yes they are plugged in properly. Any and all help is greatly appreciated. TIA
One had an arrow to the front. That one is on the right way. the other side didnt have one so i pointed the connector the same way. That could be the problem one. I may try and reverse it. Thank you two for replying. I really cant afford to take it in and have it scanned.
I've never seen an auto parts store be able to scan ABS codes. He didn't have a problem with ABS until he installed the bearings. One of them is not reading correctly.
I had the same problem with a new set off ebay, seller sent me another and no issues. Also as pointed out they have arrows they need to face. Good luck!
Moderator
If the bearings moved your wheel position on the
spindle then the ABS sensor may need to be moved
to follow. But you'd think that would be unlikely if the
bearings were right. It might also just be something
electrical came loose during the mechanical work, a
piece of tramp iron found its way to the pickup, or
some such.
some such.
if you bought the hub ***. make sure they are the same width as the old ones. But im sure you said bearings so this make me believe one of them, or both of them may have not been intstalled properly throwing your hub out of wack. The abs runs off of magnets. I wont get into how this works but if the thickness is altered in any way it throws off wheel speed sensor reading. If it reads wrong you abs will come on(due to a bad input. this also means you have no abs at the moment) just double check your work and clean out the connectors while your at it. You also could have damaged the ring the sensor reads on the hub. Good luck. let us know when you found the problem.
I finally had time to work on it. I switched the old hub/sensor assy with the new one. (The one without the direction arrow.) No more light. Just my luck, buy the best part possible and it fugged.Oh well , thx again.
