replacement factory style front lower control arms?
Old 04-06-2013, 03:19 PM
tony1784's Avatar
Default replacement factory style front lower control arms?
is there a place they are available from?
working on a v6 car that need pretty much every front end component, and dont feel like playing the press in the bushing game.
Old 04-07-2013, 01:51 PM
leadfoot4's Avatar
Have you tried a dealer, or any of the Internet GM parts sellers?
Old 04-07-2013, 09:20 PM
tony1784's Avatar
dont want to go GM, because therye like $400 list or something like that. still almost 300 from gmpartsdirect.com..
was looking to see if anyone knows if a Chinese company makes them now.
Old 04-07-2013, 10:03 PM
trans_am7935's Avatar
if all it needs is bushings, when why not take it to a body shop, and have them press in the new bushings. the stock GM pieces are probably stronger then any stock style replacement. it should be pretty cheap to just get the old ones pressed out and new ones pressed in.
Old 04-07-2013, 10:19 PM
tony1784's Avatar
because on some cars the complete cheapy loaded control arms are cheaper than buying bushings, balljoints, and paying someone to press the old ones out/new ones in.
Old 04-08-2013, 06:02 AM
leadfoot4's Avatar
Do you really want to "cheap out" on the parts that keep the front end of the car off the ground, and also allow you to keep the car under control???
Old 04-08-2013, 08:53 AM
tony1784's Avatar
yes. yes i do.
we do it all the time for work. dorman(aftermarket parts company) makes loaded control arms for 90% of the daily drivers we see and work on. sure we could buy from a dealer and pay double.. or we can buy a repop part for less and actually get a warrenty on the part.
Old 04-08-2013, 09:29 AM
1981TA's Avatar
Tony, I parted out a 2000 z28 and have the complete K-member, steering rack and front suspension intact. I want the brakes off of it, but will sell the rest. I'm not looking to make a mint off of it. But, this way, you'd also get the V8 rack and have the option of driving around a bit while doing whatever mods on a spare piece.
The car I pulled this from was abandoned, not wrecked. If you're interested, PM me. I'm in NW indiana and frequently drive to Omaha. Batavia is along the way. My next trip is in two weeks.
Old 04-08-2013, 12:34 PM
elis94camaro's Avatar
I dont think there is any loaded control arms for fbody because i was looking for some but instead payed a shop 32.50 to press in my balljoints and bushings into my stock lower control arms on each side for a total of 70 dollars
Old 04-08-2013, 06:22 PM
guy7bmwm83's Avatar
I too recently had a shop press in new bushings and ball joints on my lower arms. New arms from GM are about $220 per side (not sure if this is just the arm or not). I got my ball joints (acdelco) and bushings (moog) at rockauto.com. The arms are not damaged so I reused them.
Quick Reply: replacement factory style front lower control arms?
