matching swaybars
Old 04-23-2004, 01:57 PM
Ackattack1's Avatar
Default matching swaybars
To start off, I used the search, and didn't find the answer I'm looking for.
Anyways I'm looking for a rear swaybar. I was originally thinking of a 21mm 1LE bar, but then after reading, I may want to go bigger. Suggestions.
I have a 35mm ST front bar with cut stock springs. Eventually I'll be going with lowering springs and better shocks. I'll probably go with a lighter spring (less spring rate) and keep the bigger sway bar so that the highway driving isn't comprimised too much. My goal is to set it up for autocrossing.
I haven't autocrossed for awhile (been concentrating on drag racing, but I hit my goal, so I'm moving on to autocross) with the stock setup (as I'm sure most of you autocrossers know) the car pushes in the corners like a big fat pig. I am now thinking that by going with a 1LE bar, it will retain this understeer tendency, and that by going with something like a 24mm bar, I may be able to tame this down a bit? Am I on the right track?
Thanks
Old 04-23-2004, 02:58 PM
2000Z28M6's Avatar
most people will tell you the same thing, 21mm to 24mm is a personal preferance and will be influenced by your driving style. Some feel the 24mm causes the rear to be a bit loose and even suggest dropping to a stock 19mm. I like my setup primarliy since it helped with some of the fishtailing.
Quick Reply: matching swaybars
