problem with bottom strut bushing,qua struts
Old 04-26-2013, 07:09 PM
SPRAYED 01's Avatar
Default problem with bottom strut bushing,qua struts
I run qua struts and 275lbs spring. on the left side, where the strut bolts to the control arm there are 2 half bushings. they are held together with 2 snap rings. my issue is that the snap ring will come out of the groove and the bushing will slide out and get ruined. this is my second lower rod that the bushings go on. ive changed the snap rings also. any one else?
Old 04-26-2013, 07:36 PM
SPRAYED 01's Avatar
sorry i mean qa1 struts not sure what happened there
Quick Reply: problem with bottom strut bushing,qua struts
