Will 13" Cobra Calipers/Rotors work on 02 Camaro?
Old 04-30-2013, 07:25 PM
bwolfZ28's Avatar
Default Will 13" Cobra Calipers/Rotors work on 02 Camaro?
I've got a set of 13" rotors, and calipers from a cobra mustang. I was wondering if anyone knows if theyll work on an fbody. Or if anyone has a link to how to set them up. Thanks
Brian
Old 05-01-2013, 01:34 PM
2kblackgtp's Avatar
You will definitely need to have the rotor drilled for proper bolt pattern. Take a stock rotor and the cobra rotor, compare the inner diameter to see if it will clear the hub. Also compare height of the rotor from the mounting surface on the hub to the front and back faces of the friction surface to understand where the friction surface of the rotor will sit. Too far out and your caliper can rub the wheel, too far in and you may have no room for a caliper adapter mount. You may be able to have a caliper adapter fabricated if the rotor doesn't get in the way.
With that being said, it won't be a direct fit and unless you have fabrication skills, tools and materials, which I'm assuming you don't, you would be much better off buying a ctsv setup than having a set of one off brackets made.
Old 05-01-2013, 01:50 PM
Atrus_SS's Avatar
I hear if you put Ford parts on a Chevy, it'll burst into flame.
I agree, it'll be more trouble than it's worth IMO.
Old 05-01-2013, 02:19 PM
03Sssnake's Avatar
chevy parts on a ford to make them fast, not the other way around!
Old 05-01-2013, 02:25 PM
therealcreeper's Avatar
which is precisely why it WILL work...since they're brakes
Old 05-01-2013, 02:31 PM
03Sssnake's Avatar
well played!
Quick Reply: Will 13" Cobra Calipers/Rotors work on 02 Camaro?
