Help with MWC Tunnel MountTorque Arm Install
I have a MWC tunnel mount torque arm for a true dual exhaust setup. I have searched, but unable to find any good pictures of this torque arm installed. I would also call MWC, but I need to get the TA on this weekend to make a dyno appointment next week. Here are a few pictures of the TA and Mount:
Questions
1. Does the TA install with the adjustor/long side toward the ground or toward the car?
2. The pivot link on the forward mount hits the tunnel when installed. I have noticed in some pictures this has a pivot link with 4 holes and some show it with 2 holes. Do I need to get a new pivot link or cut this one to fit?
3. Is the bracket on the rear of the TA that bolts to the rear end on backwards?
4. Which set of holes is used on the bracket with a Moser Standard 9"? How much grinding is usually needed to make it fit?
Questions
LS1Tech Premium Sponsor
you have it assembled correct for the duals crossmember, however it looks like we sent you the wrong link as it has 4 hole and should only have 2, thus the tunnel contact. The two links are the same basic thing, just one you have is longer by two holes. We can get you switched out no problem, but if you are in a time crunch then simply cut off the two top holes and run it that way.
Did you get the issue straightened out? I'm in the same boat as you right now. I have the two hole on the cross member but with the adjustment up top it makes it very difficult to adjust it, and with the adjustment on bottom the torque arm is hitting the floor.
Adam
Adam
Sorry to bump an old thread. I recently bought a MWC true dual tunnel mount torque arm setup and installed it. It come bolted together and the adjustment is on the bottom along with the front rod end on bottom. I had some trouble as it was a tight fit but was searching and found this thread. My arm is mounted opposite of the first pic in this thread. Just wanted to verify.
