bump stops hitting rims and tires..and saggy springs
They are hitting pretty bad, anyway to move the stop so it wont hit? Tried smashing it in with a BFH it still hits when i raise the car up. I have all stock springs and the car seems to sit like it is lowered.... is there some type of spring with same coil rate but longer? Put on my rumbler TPS last night and its about 1" off the ground ttttt i messed with adjusting the pipes around for over 3 hours just to get it to not drag. thanks for help
isolators? the rubbers on the end? it has that and yes i got them from a guy on here after i cut mine and it was really low to the ground....i do have a wings west double spoiler on the back that is a little on the heavy side.
