ABS INOP light 95 Z28
Old 04-25-2004, 11:13 PM
95CAMz28's Avatar
Default ABS INOP light 95 Z28
Why does this ABS INOP light stay lit? I can tell my ABS brakes are working fine and the fluid level is good. This is a 1995 Z-28 with everything stock but the exhaust & a K&N cold air kit.
Thanks
Old 04-26-2004, 11:05 AM
Copy & Paste Moderator
VIP1's Avatar
Did you get the car dynoed recently. If so, it could have caused that light. The computer gets confused when there is such a big difference in wheel speed (front to rear).
--VIP
Old 04-26-2004, 04:10 PM
95CAMz28's Avatar
How do you un-confuse the computer?
Old 04-26-2004, 04:19 PM
VIP1's Avatar
It should clear up after a while. An alternative would be to use LS1Edit (I think).
--VIP1
Old 04-29-2004, 07:37 AM
95CAMz28's Avatar
It's been on for over a month.
Old 04-29-2004, 08:27 AM
VIP1's Avatar
Thats way too long.
Check all the sensors (one at each wheel). Unplug them and replug them in to make sure they are properly seated. Often one will be loose or damaged.
--VIP1
Old 04-29-2004, 05:05 PM
VIP1's Avatar
In another thread, someone mentioned a possible issue with tire diameter.
Are you running the same height tire front and rear?
If you are running "bigs and littles" it may cause those lights to come on.
--vIP1
Quick Reply: ABS INOP light 95 Z28
