single adjustable Poly/rod lost.
So i've got a single adjustable Poly/rod setup for my T/A recently and i've installed the phb and i came up with an idea to adjust it (push the car left or right depends on where it needs to be centered).
but now i'm concerned about the LCA's how do you adjust those !
i certainly can't push the differential to the front or back suspension loaded or not !
single adjustable setup's aren't easy to deal with i've recently heard & i made the mistake cause i didn't pay much attention i guess
any help is surely appreciated.
thanks guys
thanks guys
Trunion King
thanks guys
thanks guys
thanks guys
thanks guys
Do you have access to a 4-wheel alignment rack? Ideally, you get the car on the rack, with the alignment heads on the wheels, and adjust the "rear toe" to zero. Most cars have a little mis-alignment in them (manufacturing tolerances), and it shows up as toe in on one side of the car, and a little toe out on the other, because the car has a solid axle.
i've just took some measurement's and the tires seem to have a 2" space from the each tire to the back of the rear bumper. which kind of tells me they are centered, but i'm somehow convinced that with the LCA install they'll get screwed.
sideways though the right side has 2.75" & left 1.75" < can fix that
still looking for more idea's here.
.....i could get access at a shop..
Just to give you some practical advise, measuring from the body panels is OK, but not the most accurate, as there are manufacturing tolerances there, too. Centering the rear axle under the car, with an adjustable PHB, by all means, measure down from the sides of the car to the edge of the wheels, because A) this measurement doesn't have to be "dead nuts"; B) the measurement will change as gas is added, people sit in the back seat, etc; and C) other than tire clearance, a little bit of variation isn't critical.
However, if you're going through the effort to buy and install a pair of adjustable LCAs, and you want to get the most out of them, you want their length adjusted properly. Part of their benefit, is to be able to get the rear axle TOTALLY parallel to the front end. While a ruler gets you close, the difference in the lengths of the LCAs, side to side, could differ as little as 0.020-0.030". It's EXTREMELY difficult to get that close without a 4 wheel alignment rack.
