LCA removal..
Old 06-05-2013, 09:29 PM
JustAFooL's Avatar
Default LCA removal..
Is it as simple as it looks? There is a rod run this Saturday and my lower ball joint went out. Thought I could get it changed but I can't seem to get it to o back in straight. I'm just going to take it to shop and let them press it back in but I gotta be able to remove it tomorrow night with no holdups. Looks like there was just 2 bolts.. Advice?
Old 06-05-2013, 10:16 PM
FormulaJoe's Avatar
The front horizontal one is really easy to get out. Just turn the steering all the way to the side your working on so you have room to wiggle the bolt past the rack tie rod boot. The rear one is a PITA for most people.. I'm in the middle of doing bushings, ball joints, and shocks with new mounts, and I had to cut out the rear vertical LCA bolt with a sawzall on both sides of the car.. There are a few threads in this forum about the front LCA bolt..
Old 06-06-2013, 06:23 AM
JustAFooL's Avatar
Dam, it figures.
Old 06-06-2013, 07:24 AM
SparkyJJO's Avatar
Mine came out just fine.
Old 06-06-2013, 08:32 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Generally it really isn't too bad of a job at all, the only time it gets crappy is if the hardware is frozen.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 06-06-2013, 11:31 AM
JustAFooL's Avatar
I'm going to go buy and hand held torch today and attempt to heat the ball l joint hole and stick the ball joint itself in the freezer. If I still can't get it in, I'll take the arm off I guess. My luck, it will be froze.
Quick Reply: LCA removal..
