vibration getting worse
Old 06-08-2013, 10:20 PM
spdygon's Avatar
Default vibration getting worse
Ok.....back in 2011 hrpt notice a vibration passed 70. Car is not a daily driver so only for shows and cruise night do i drive it. Just got back from this years tour and i could not drive pass 70 without the vibration. It only vibrates under load any time pass 70.....going up hill....picking up speed. So what I did was I would speed up to 90 and let off the gas and the vibration would stop...... did these with trans in gear and off gear. So got home set the car on jack to check for any loss suspension parts but everything check ok....only thing i found was on the rear u-joint looks like it had a bridge/metal connecting from one end to the other but was broken on one end. So I remove it. Also notice some play on the wheel not from the wheel itself but from where the axle would be in contact with the bearing.
Any ideas?
Quick Reply: vibration getting worse
