Rear Spring + Sway Bar & Torque Arm
Hi Guys,
Daily Driver with ROD's because = RANDOM OVERTAKING DAILY
Current Suspension:- All Stock + Front Sway bar!+ Founders (PHB & PH Relocation + LCA & Relocation (ROD/ROD everything). Now I know how my Sway bar links got lose a week later
I got at home :-
1. QA1 Single ADJ F SERIES Front Coil overs & Rear Shocks along with 300lb springs for the fronts.
2. UMI Front UPPER & LOWER - ADJUSTABLE A-ARMS
Help & Suggestions:-
1. Suggestions on new rear springs (Currently some yellow crap springs is on the car) - Something that wouldn't ruin the stance with a 295/45/18 or 28.4" tire
2. Suggestions on Rear DRAG Bar + End freakin links- (UMI & BMR)
3. Suggestions on ADJ Torque Arm - (UMI & BMR)
(Possible rear upgrade within the next year)
I got at home :-
LS1Tech Premium Sponsor
Hi Guys,
I got at home :-
I got at home :-
As far as ease of installation and performance goes it is hard to beat our BMR xtreme anti-roll bars. They are 100% bolt-in with no welding required so the installation is about as easy as it can be. Our BMR xtreme anti-roll comes as a complete kit so there is nothing else needed for the install.
You can't go wrong with either adjustable torque arm honestly but I personally prefer the design of our rear mounting bracket a little better but both are quality pieces.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
assuming both me & the OP are sooner or later going to change our 10 bolts.
regarding torque arms as the OP stated & is also my way, if i'm getting a rear end say a 9" or any other out there in the market wouldn't leaving the torque arm be until i get the rear end? to make sure which one fits my rear end?
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Any of our BMR torque arms will fit the 10 bolt or any of the aftermarket options out there with a little trimming of the mounting bracket where the torque arm mounts to the rear end. With both the 12 bolt rear ends and the Dana 60 rear ends that rear bracket has to be trimmed to get the torque arm to mount up because of the way the rear ends are cast. On most of the 9 inch rear ends our torque arms should bolt up without any trimming of the bracket. So if you buy a torque arm while you have a 10 bolt it will swap over to your aftermarket rear end with a little trimming of the mounting bracket at the most and this one of the reason we have two sets of holes in our torque arm brackets.
How compatible is it with Dana 60 Vs Strange or 9" rear ends ?
