UMI torque arm relocation with poly transmission mount???
Old 06-17-2013, 07:04 PM
white3800camaro's Avatar
Default UMI torque arm relocation with poly transmission mount???
Upon installing my new UMI cross member, I noticed my mount no longer lines up.
Any solutions?
Dremel to fit?
Old 06-17-2013, 08:45 PM
No one has installed the UMI torque arm relocation with a poly bushing and
4l60e?
Old 06-17-2013, 09:15 PM
sjsingle1's Avatar
pics?
UMI Sales's Avatar
Thanks for choosing UMI.
Did the factory trans mount fit and the poly doesn't?
Did you leave everything loose until all the fasteners were in and then tighten?
Thx
-- Ramey
Old 06-17-2013, 09:27 PM
UMI Performance's Avatar
The factory mounts have the mounting stud off set while the poly mounts place the stud in the center. This slight difference in stud location occasionally causes an issue. Make sure all four bolts that mount the crossmember to the car are loose and see if it lines up better that way.
Hope that helps,
Ryan
Old 06-17-2013, 10:24 PM
I left all of the bolts loose on the mount and cross member.
I will mess with it more in the morning.
As it is now it only lines up with the first hole.
I also need the little aluminum spacer for the torque arm bushing.
If I cannot make this mount line up without too much modification any suggestions?
Attached Thumbnails UMI torque arm relocation with poly transmission mount???-355-3-1158r.jpg
Old 06-18-2013, 04:17 AM
You will want to use the middle hole, it sounds like your transmission is just shifted to the side slightly. You will need to pull it over while installing the bolt.
Hope that helps,
Ryan
Old 06-18-2013, 05:18 AM
bufmatmuslepants's Avatar
Nothing a big bar wedged between the tunnel can't move.
Quick Reply: UMI torque arm relocation with poly transmission mount???
