2001 camaro ss best stock spring
Old 06-20-2013, 09:52 PM
lefty2023's Avatar
Default 2001 camaro ss best stock spring
hello, I've exhausted my resources searching for stock replacement for my rear springs. I dont know what the stock specs are so I'm having a hard time figuring out what im buying. Just trying to stop the rear from sagging. Is there a big difference between these two shocks??
http://www.moog-suspension-parts.com...rod=MOOG-CC635
http://www.spohn.net/shop/1998-2002-...ings-Pair.html
Old 06-21-2013, 03:25 PM
crw3673's Avatar
well I'm no expert, but the first set are moog front springs. listed at 518lb of load weight. The next listing is for moog rear springs. Moog is not performance oriented, like other brands. They deal with factory replacement, not performance upgrades.
Old 06-23-2013, 08:26 AM
therealcreeper's Avatar
the spring rate is 104, I believe the 1st set are rears and the picture just isn't accurate
Old 06-23-2013, 03:15 PM
sjsingle1's Avatar
there is a spring rate test around here somewhere...........the moogs were a hair stiffer than stock if i remember
Old 06-23-2013, 11:48 PM
libertyforall1776's Avatar
4th gen Fbody Spring Rate Database
(Progressive springs are listed with initial and final spring rate)
Manufacturer----------------Model--------------------Front (lbs/in)--------------Rear (lbs/in)------------------------Ride Height Drop (in)
OEM------------------------GM V6 93-97------------------223-----------------------95.4--------------------------------------0.00"
OEM------------------------GM V8 93-97-------------------310-----------------------110---------------------------------------0.00"
OEM------------------------GM V6 98-02-------------------257-----------------------114---------------------------------------0.00"
OEM------------------------GM V8 98-02-------------------292-----------------------114---------------------------------------0.00"
1LE-------------------------GM 1LE-------------------------360------------------------130-180---------------------------------0.00"
Eibach--------------------- V6 Prokit 93-97----------------337------------------------75-135----------------------------------1.00"
Eibach---------------------V8 Prokit 93-97-----------------377-600------------------94-160-----------------------------------1.30"
Eibach-------------------- V6 Prokit 98-02-----------------351------------------------80-137-----------------------------------1.40"
Eibach---------------------V8 Prokit 98-02----------------400-------------------------80-137-----------------------------------1.25"
Eibach---------------------Sportline------------------------360-----------------------80-137--------------------------------1.6" / 1.4"
Hotchkis-------------------Fbody Springs------------------285-525-----------------100-140---------------------------------1.00"
G2-------------------------Super Springs-------------------548-----------------------180-230----------------------------------1.50"
Hyperco Hypercoils-------Fbody Springs-------------------360-580-----------------168-216---------------------------------1.25"
MAC-----------------------Fbody Springs-------------------450-515------------------215-245---------------------------------1.50"
SLP------------------------Level 1 Progressive-------------223-448------------------97-136----------------------------------0.75"
SLP------------------------Level 2 Progressive-------------300-450------------------115-185---------------------------------0.50"
BMR-----------------------Fbody Springs(older spec)------310-550-------------------145-170---------------------------------1.00"
Suspension Techniques--Fbody Springs-------------------428-----------------------161-----------------------------------1.30" / 1.70"
Edelbrock-----------------Fbody Springs--------------------585------------------------120-150--------------------------------1.25"
DMS Springs--------------LS1 98-02----------------------325-630-------------------95-160----------------------------------1.30"
Strano --------------------F body springs------------------550-------------------------150-------------------------------------1.25"
BMR-----------------------performance spring(new spec)-550-------------------------160-------------------------------------1.25"
Vogtland-------------------F body spring-------------------440-542--------------------183-228--------------------------------1.2"
Quick Reply: 2001 camaro ss best stock spring
