Stuck nut on coil over bolts
Old 06-22-2013, 09:57 PM
HeavyGlock's Avatar
Default Stuck nut on coil over bolts
Hi guys, I had no idea this would be such a problem but I cant find a way to get 1 bolt out of my front coil over to pull them out. The problem is the top 4, 2 are nuts the other 2 are bolts going into a half rubber half metal circular nut. Well both are rusted tight, I got vise grips on the outer one and it came right out. The back one I can barely touch with my fingers let alone hold it tight with anything. Didn't know if anyone else ran into this or has any tricks to get it off.
Old 06-23-2013, 06:44 PM
HeavyGlock's Avatar
I just cut the head of the bolt off. No other way I guess.
Old 06-23-2013, 08:57 PM
trik396's Avatar
Did you get the shock off yet??? That is the one that was really fubar for me. Ended up getting new upper strut mounts from rock auto.
Old 06-25-2013, 09:07 PM
HeavyGlock's Avatar
Yea I grinded the bolt head off and it fell right out. Ill just get new bolts and nuts. I could see why you would replace it though. Mine could prob stand to be replaced too.
Quick Reply: Stuck nut on coil over bolts
