Final Stance
Old 06-23-2013, 05:12 PM
ZForce1's Avatar
Default Final Stance
So, I finally got my car's stance the way I wanted it. I installed Strano springs, then UMI 1" lowering A-arms to drop the front a little more. The a-arms slammed it, so I raised it back up 7/16" by shimming the lower shock mount. A bit expensive but I wasn't going to be satisfied until I got it right.
Old 06-23-2013, 05:18 PM
Zlow28's Avatar
Unfortunately where i live, i cant enjoy a car that low, but it looks good!
Old 06-23-2013, 09:54 PM
00transamws6's Avatar
Looks good.
Old 06-24-2013, 05:06 AM
38DD2436's Avatar
I like the "level" look.
Old 06-24-2013, 02:09 PM
bigken's Avatar
Looks good bro!
Old 06-24-2013, 02:27 PM
Flubyux2's Avatar
Are those all before shots?
Still looks like a normal and sensible ride height.
Old 06-24-2013, 03:07 PM
hardbones's Avatar
Location: Illinois, as close to "Normal" as I can get...
Nice!
Old 06-24-2013, 04:09 PM
ThoR294's Avatar
the level look is so weird! lol I like it
Old 06-24-2013, 05:58 PM
ZForce1's Avatar
Those are after pics - before it sat on 4x4 truck suspension. From the factory it came with 16" rims, and the wheel gap was much bigger than even this if you can believe it. I don't know what GM was thinking. Check it out:
Old 06-24-2013, 10:50 PM
ThoR294's Avatar
yeah my 4x4 gap was terrible... stranos fixed it right up thank god. car looks so much better.
Old 06-24-2013, 11:20 PM
Skraight's Avatar
How easy/how long did the a-arm install take?
Thinking about picking them up as well.
Old 06-25-2013, 02:30 AM
Flubyux2's Avatar
You might just have had shorter tires making the fender gap worse than stock.
I purposes have used tires 26" or slightly taller just to fill up the gap.
Old 06-25-2013, 07:28 AM
01Z0H6's Avatar
Looks good buddy...
Old 06-25-2013, 05:56 PM
ZForce1's Avatar
The a-arms took me pretty much a whole day to install. I had a hard time getting the fwd bolts out at first, until I learned the trick to it. I also had a tie rod end start spinning on me and had to replace it. Of course, the nut to it was stuck solid. I could probably do it again in half the time.
Old 06-25-2013, 06:16 PM
Empatho's Avatar
looks really good
Old 06-25-2013, 06:34 PM
GMC5.3's Avatar
Any pics of the slammed look, before you raised it?
Old 06-26-2013, 02:28 AM
99Bluz28's Avatar
Looks good, but when did UMI come out with a 1" drop A-arms...?
BMR is the one I know that has a 1" drop A-arms.
Old 06-26-2013, 02:33 AM
02TransAm/Batmobile's Avatar
If they truly are 1" lowering A-arms, with the Strano springs and 7/16" shim, that comes out to a 1.7625 drop. Yet it still looks like only a modest drop?
Old 06-26-2013, 02:38 AM
lemons12's Avatar
Needs moar low.
Old 06-26-2013, 03:15 PM
homerunhtr21's Avatar
What size tire are you running? It looks like it dropped about an inch. That's a lot of money for an inch
Quick Reply: Final Stance
