Adjusting ride height with QA1's or Vikings??
Old 07-01-2013, 02:45 PM
Ryanbgb22's Avatar
Default Adjusting ride height with QA1's or Vikings??
I just purchased a set of Viking coil overs with the 550 spring rate. I put them on my car and wanted to lower the front to about the height I had it with the Eibach Sportlines.
In order to get my car that low, I had to move the bottom support down so low that the spring no longer has ANY preload. It has about an inch of space between the bottom and top support.
Is this normal? Can I run the car like this? Are the vikings even supposed to be able to lower the vehicle (I was told you could go as low as you want with them when I purchased).
Old 07-02-2013, 08:40 AM
Ryanbgb22's Avatar
bump...
Old 07-02-2013, 10:30 PM
Midnight02's Avatar
Bump...would love to see the answer as well.
Old 07-02-2013, 10:36 PM
UMI Sales's Avatar
We have our WS6 super low. There is a gap above the spring when the car is in full rebound, i.e. jacked up.
We ran 200 auto-x laps and 300 highway miles last weekend w no trouble.
You should be good to go.
-- Ramey
Old 07-02-2013, 11:50 PM
99Bluz28's Avatar
What's the spring length, 14" ?
Old 07-03-2013, 05:00 AM
Flubyux2's Avatar
You'll have to look into tender springs. They will keep tension on the springs when the suspension droops. It prevents the normal service spring from unseating or clattering. This is the right way to build coilovers if you don't have separat preload and height adjustments.
Old 07-03-2013, 07:36 AM
UMI Sales's Avatar
12" 550 lb/in
Tender springs may help but would add to minimum ride height, at least with that exact spring.
ramey
Quick Reply: Adjusting ride height with QA1's or Vikings??
