Can you remove SFC's?
I was wondering if you could remove subframe connectors? When I re-do my suspension, I'd like to remove them, and add BMR's to the car. The ones I have now are some cheap/dinky ones, and I am trying to get rid of any/all twist that may occur. Right now, it's "ok", but adding about 200+rwhp to my current set-up could possibly make the job of these a little more difficult. I would think you could just cut them off? Smooth out where the welds were, adn then re-weld the new units on. But, would using a torch hurt the floorpans? Or, weaken anything on the car?
I would avoid using a torch, get yourself a cut off wheel http://www.homedepot.com/prel80/HDUS...ceffdfgidgkk.0 , grind only the welds or the metal will become paper thin.
Al
Al
Sweet, I just bought one of those to help a buddy cut off excess threads on a set of spring compressors. I guess you're right, I would just need to cut the welds around the edges of the subframe. And, once I got it off, grind it down smooth, am I correct?
I was wondering the same thing! I was told my torque thrust alignment was off and i was curious if i could cut out my BMR boxed SFC, get that torque thurst alignment adjusted and then have my SFC re-welded in? or would i need new ones ?
