torque arm
torque arm
I know same old thing. The car a part but what is the best torque arm . Tunnel mount or tran mount. Need to know so l can order one. Thanks
Super Hulk Smash
I'd do the trans mount. The tunnel mounts make more noise and limit your exhaust options.
If you are worried about your trans tailshaft, you can get a trans relo crossmember that allows for trans mounted TAs to work. It also beefs up the rear trans mount. That's costly though.
For a street car a long style T/A is best. A short arm will cause brake hop under hard braking because of the short leverage point.
The relocation crossmember allows you to change your I/C which helps when you launch. You can move it all the way up and not have any adverse effects.
I have the UMI long T/A with the relocation crossmember and I love it.
I'm not saying this to sell my TA either.. I'm saying this as my experience with a short TA.
I drove it for 2 months and would have never known it was a short arm unless I knew it was there.
It has 450 rwhp. It m6 stock rear with 4.11 lower an the bolt on rear end parts.l would like to ho autocrossing with it an littel down the stripe. Thank for the help
LS1Tech Premium Sponsor
BMR full length adjustable torque arm (TA001)
BMR T56 torque arm relocation crossmember (TCC006)
Definitely stay away from the short style torque arms because they will induce brake hop under very hard braking and that is not going to be something you are going to want to mess with while autocrossing.
If you have any questions or if there is something we can help you out with let us know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
If you are interested in some pricing I can point in the direction of a stocking UMI dealer with great pricing.
Also if you have any questions we are happy to help.
Thanks!
Ryan
