Koni Shock Adjustment Issue
So I bought some Koni 4/3 shocks with Strano springs from a forum member for around $700. The shocks/springs were lightly used and appear to be in great condition. Everything looked great and I'm not sure if I'm doing something wrong but for some reason I can't get one of the front shocks to adjust....I turn the adjustment wheel using a small hex tool I had laying around but it turns infinitely and has very little resistance. Is there anything I need to do to get the adjustment wheel to catch or is it probably stripped out? I know on the rears there was a button I had to press. The other shock adjusted fine and I brought it 4 turns from full hard.
On a side note, the install went pretty well and I love the new lowered look on my car. Ride quality isn't that great because I'm currently running without a front sway bar until I can get new end links....ended up breaking them.
Thanks in advance.
Thanks in advance.
LS1TECH Sponsor
It's broken. Bottomed out internally that's why the adjuster freewheels. Koni has a lifetime warranty but only to the original owner. You can call them, and they could fix it, but that will cost close to as much as a new shock (and take 6-8 weeks on top of it).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Would you sell a single and how much?
LS1TECH Sponsor
Sure... they are still on sale too. $270, $10 shipping and I have them in stock. Normally $325 or so each.
__________________
LS1TECH Sponsor
You can order a single on the site... just remember we don't take CC's on site *for your protection*. A CC# not online is one that can't get hacked. Submit the order, and we'll call you back for payment, it's that easy.
Sam
Sam
__________________
