Help with BMR 1 inch lowering a arms
Old 09-09-2013, 07:59 PM
Zark's Avatar
Default Help with BMR 1 inch lowering a arms
I recently installed a set of BMR 1 inch lowering a arms, Koni shocks, BMR springs, and new shock mounts, isolators etc. I am having a problem getting the shocks to line up with the holes in the a arms. I assume that I will just have to adjust the rear bolts on the a arms, however I wanted to get a second opinion before I go messing with my alignment settings. Here are some pictures of the shocks, you can see how they don't line up with the bolt holes on the a arms. Any help would be appreciated
The first two pictures are of the passenger side, the next two are of the driver side.
Old 09-09-2013, 09:06 PM
99Bluz28's Avatar
Your alignment was off as soon as you loosened your factory A-arms before replacing them with the BMR A-arms. So you're going to need to get a new front end alignment anyway.
Old 09-09-2013, 09:15 PM
Zark's Avatar
Yes I am aware of that, I guess I should have clarified my question. I am asking if adjusting the rod end of the new a arm out a bit more will help line the holes up more, or if perhaps I made some other error somewhere that I overlooked.
Old 09-09-2013, 10:21 PM
99Bluz28's Avatar
I'd leave both the L & R A-arm rod-ends adjusted to the same length and just move the A-arms around with in the adjustment slots on the K-member until the shock mount bolt holes line up with the mount holes on the A-arms. Then try to get the bolts moved back as close as possible to the original locations, so you'll be able to drive it to the alignment shop.
Old 09-09-2013, 10:29 PM
scj
scj's Avatar
^ word.
Old 09-10-2013, 01:15 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I honestly couldn't have explained it any better. Do this and if you still have an issue get with me and we can work through whatever you run into.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 09-10-2013, 06:20 PM
Zark's Avatar
Thanks for the help everybody I will definitely try this tonight. I do have one question though, once I get the shock bolts into the holes on the a arm, won't adjusting the alignment bolts back to (or as close as I can get them) to the stock locations put excess stress on the upper shock mount bolts? I am not questioning your advice just wondering why this is okay, This is my first time ever doing anything with car suspension. Thanks again everybody.
Old 09-10-2013, 06:32 PM
GMC5.3's Avatar
This is good info, I forced my shock to slight the holes, must be why I pull to the left now.
Old 09-10-2013, 08:24 PM
99Bluz28's Avatar
No, you alignment is off, that's all.
Old 09-10-2013, 08:29 PM
99Bluz28's Avatar
The shock shaft is mounted in rubber(in the upper mount) to allow for movement(alignment or normal A-arm movement) of the lower shock mount location.
Quick Reply: Help with BMR 1 inch lowering a arms
