Best suspension?
Best suspension?
Looking at upgrading my suspension fixing all weak points possible and just wanting to hear different opinions on brands and what to get suspension wise minus a tubular k that will be later down the road if at all
Bmr umi founders, all really good companies. I personally went with founders, can't beat their prices. I have adj pan hard rod. Lower control arms and relocation brackets. Great products at great prices. Going to order their new torque arm and subframe connectors in the coming months.
750-800rwhp and a tubular k-member is out of the question for right now? Sounds like the motor is definitely going to be out anyway, why not put a k-member in and lighten up the front end and increase room while you're at it?
A typical list would include lower control arm relocation brackets, tubular a-arms, and subframe connectors, but for a car with that amount of power, you're going to need a new rear end more than likely. Midwest Chassis is a one stop shop for anything and everything you'd need, and their rear ends are second to none IMO on quality and pricing.
I'm going all BMR/UMI Chromoly and tubular from A-arms, K-member, torque arm, LCAs, relocation bracket weld in, cross member, PHB, subframe connectors weld in,strut tower brace, with either bilstein or Koni shocks/struts and Strano springs
I'll be at around the same HP doing mostly street driving and some AutoX and mountain driving
Edit: I'm also doing all of this plus rearend + drivetrain before I touch more power.
Gotta be able to put down the power and handle it before you add it. Then again I like to do things once the right way
LS1Tech Premium Sponsor
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
