Need help with brakes
I have a 95 V6(3.4) Camaro that I am swapping for an LS1/T56. Well it has disc in front and drums in the rear. I want to know exactly what Ill need to get the 98-02 style disc brakes on all 4 wheels. I will be installing a Strange S60 rear end in before the car ever touches the ground so I want to get it all done now before its ready to be driven. I know for the front brakes Ill need the spindles from an LS(already have them) as well as the rotors, but what about the calipers?
Also what about when I am ordering my rear end what should I do? Just have them build it for use with 98+ style rear brakes? If so then what do I say about 3ch or 4ch,etc..
Just kind of lost as to what I should do. I have the ABS controller that sits in the front driver side of engine bay from a 2000 Z28 I had as a donor car(didnt think about the brakes before I scrapped the car), but someone told me it would be a problem as far as electrical wiring goes to swap the ABS controller from the 95 to the 2000 controller.
Hope all that made sense. If anyone can help me out please let me know.
Thanks in advance,
Brenton
Thanks in advance,
Brenton
As far as ABS, I haven't done an LS1 swap so the wiring might be an issue with the 93-97 ABS module.
You'll need everything I listed above. You basically just take everything off the axle tubes from a 98+ car. And you'll need the e-brake cables. You need the two that go from the e-brake itself to the little bracket mounted under the tranny tunnel. You'll know what I mean when you go to take them out.
