What is this and what does it do?
See attached. Picture is from when I discovered the leak, before I drove a screw through it. I realize this is a major newb question, but I'm new to doing work on my own car.
When I was reinstalling my intake, I couldn't get the intake to fit in, so I removed the nut closest to the front of the car on this box (whatever it is) and put it back in, ended up making no difference, so I put it back in.
Brakes got all spongy, looked and noticed it started leaking out of that nut. I tried tightening the nut more, ended up snapping it off. I drove a screw through it to stop it from leaking. So now it doesn't leak.
1. What does this entire box do?
2. How do I cure the spongy brake pedal now that the fluid leak has stopped?
3. Should I do a more proper fix on what I broke?
Location: Land of the Mormon's although I'm not one of them
The box is your ABS control module.
I can't see what nut you're talking about, or where you put the screw/etc.
Is the leak coolant or brake fluid? If it's brake fluid and you have a spongy pedal then your car isn't safe to drive, even with a screw in it.
Need more information about where it's leaking from, what nut you messed with, where you put the screw, etc.
Sounds to me like you might have destroyed your abs control module.
Why would you "drive a screw through" because it started leaking???
Lesson learned hopefully
Post a picture of what it looks like now and maybe we can let you know what all is destroyed... Or just have it towed to a good shop.
And please for the sake of the rest of the world, don't drive the car until the brakes are functioning properly.
That is a bleeder... Its just there to remove air from the braking hydraulic circuit.
Those are replaceable if you can get the remains of the old bleeder out of the bore. As for the screw, Assuming that there was part of the bleeder left in the bore, I doubt that it has "destroyed" the ABS module. (Though more than likely the threads have been nuked)
The spongey pedal that you have is probably being caused by air in the braking hydraulic circuit.
Go to a shop and get it vacuum bled, and the problem should be solved. If you have a friend who can help, they can work the brakes while you bleed them manually.
I was under the impression that he drove the screw into the abs module housing. At least that's what it sounds like to me.
