Very Odd Skewed/Mis-aligned Rearend
Well, my rear end on the driver side is centered in the wheel well by eye, but the passenger side is off a good 2 inches forward (toward the front of the car) in comparison. I noticed something off when I hit the brakes and the car jerks to the passenger side out of the blue, then I started looking around and found this. This is definitely something funky going on to me. Is this normal after having a S60 rear end swap, BMR lower springs w/ heater hose mod, stock rear decarbons, Adj. Panhard bar, NON-Adj. LCA, LCA relo. bracket, and Adj. tunnel mount torque arm???? Obviously I could just get adjustable LCA, but I'm wondering if something else could be actually wrong and needs to be fixed causing this problem that has seemed to have randomly occurred. ALSO, when jacking up the car on the center of the rear end, the passenger side sags about a inch or so more than the driver side.
I bought these LCA 4 years ago when I first started modding the car with no expectations of going this far (bolt on only mentality at the time lol...) and have had the rear end in for just alittle overa year now and didn't have problems then. Some how way or another it got out of wack these last few months. It seems as so, at least.. BUT yeah, I'll just end up investing into the ADJ. ones ASAP anyway..
It's not mine! woo hoo!
I'm not sure I'd simply just throw on adjustables and call it a day considering you're saying this just seemed to happen after having the rear fine for a year. Definitely check all your mounting points to ensure bolts are tight and nothing is bent (did you hit something recently?).
LS1TECH Sponsor
Sounds to me like the LCA brackets are not welded on the axle square.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Sent from my HTC One VX using IB AutoGroup
LS1TECH Sponsor
oh, I missed that. Read like the S60 was new. Something has to be bent.
__________________
Alright thanks for the help guys! I haven't been able to work in the car till tonight, schools took my time lol. But I did find out my ADJ panhard lock nuts were not locked on and the rear end was off that way. I haven't been able to look at the original problem yet. I'll do it when I get day light tomorrow
